I just got the Parrot Uncle F4503Q model, a remote control fan unit, and I have installed it.
After installing the unit, I turned on the circuit breaker and the lights turned on perfectly, but now I notice my switch on the wall does not work.
I can flip it on and off and my lights on the fan will stay on - the switch has no effect on the unit. The only way to turn it off is by using the remote.
When installing the wires from the receiver to the wires in the ceiling, I connected 1st wire white to white and the 2nd color from the receiver is red I connected that to black, which in the diagram says red or black. I do have a red wire from the ceiling as well, which I capped off on its own.
Should I change the connection of the red wire and black wire to red and red and leave the black wire from the ceiling capped off alone to have my switch working again?
It's my first time changing a fan, I really appreciate all the help and assistance I can get. Thank you.
