I just replaced the light bulb in the recessed light and it is working.
I noticed this strange object.
object
What is it ?
    Temperature sensor/fuse(?) What type of light bulb is it for?
    Jun 12 at 22:36
  • @crip659 so once it triggers does it reset or needs to be replaced ?
    – Ruskes
    Jun 12 at 22:41
    Unknown, some do some need replacement. Could be something also.
    Jun 12 at 22:47
  • @crip659 make that an answer and I will give you the well deserved credit. I do not need to know about UAL and Underwriters, just it is a thermal protection switch.
    – Ruskes
    Jun 12 at 23:37
    I was just guessing, @Gil gave a much better answer, including why it had to be there, which I did not know.
    Jun 12 at 23:54
10
That thermal device is a a requirement, for the recessed fixture to have Underwriters Laboratory approval. Without that approval, qualified electricians will not install them. UL states for approval a recessed fixture must have a thermal protection device built into them. I have seen two types, thermal fuses which when blow needs to be replaced or the fixture replaced. The other which most recessed fixtures have is like a thermal disk on an electric heating appliance, it snaps open then when it cools down it snaps closed. I do not know what the trip temperature is but the manufacturer determined if it gets hotter then this device the fixture becomes unsafe and a potential fire hazard. I believe this type of protection is required in all appliances etc that get hot such as coffee makers.
    It does not look like it is easy to replace, so hopefully it resets.
    Jun 12 at 22:49
  • You can take a blow dryer with the heat off and cool it that way to force it to reset but I would expect by now it has cooled. Try a smaller lamp.
    – Gil
    Jun 12 at 23:00
    OP said the light works, just did not know what the little box was for.
    Jun 12 at 23:10
