This toilet valve cover is rusted in place. I can’t slide it up or down the pipe and the pipe itself doesn’t seem to be corrosion resistant. I am worried the rust if not resolved will eat into the pipe and cause a leak. Am I wrong to worry about this?
Is a fix needed or am I just worrying for no reason. If it matters I live in a cold weather northeastern state.
Thank you
