A PRV is simply a pressure regulator.
When you moved things it may have moved the spring into a slightly different position changing the pressure as you observed.
The other possibility you bumped the adjustment screw (but these usually take a few turns for that large of a shift).
In either case it’s no big deal just turn the adjustment screw usually tighter is higher pressure watch your gauge while increasing and go slow remember the pressure may be slightly lower with a flow if you set it at static or no flow. If you set it with flow the static may be higher.
There should be a jamb or locking nut on the screw shaft, loosen this prior to adjustment and tighten after, the pressure may also change when the lock nut is tightened, if a plastic handle type knob some pull out to unlock and then push back in to lock.
