I have 2 fans on the same circuit with 2 separate switches, Not fan/light, switches are in separate rooms, either one would turn the fans on. Both fans are installed one works one does not. The non working fan has dual black and white wires
1Pictures are always helpful. Some of the before you removed the old fans pictures would be great.– JACKMay 28 at 17:14
If you'll take the tour, you'll note that this is a Question and Answer forum, not a general discussion board. So far, you've made several statements, but you haven't asked any questions. Please edit to clearly indicate what your question is. Also, please clarify the existing situation, as it is very unclear what the current situation is. Are the new fans installed, one works, one doesn't? What does "remote style" mean? What wiring does the working fan have? So many questions, so few characters...– FreeManMay 28 at 21:01
Add a comment
