I've just had a skim coat of fresh plaster put on plasterboard (mixture of screwed to stud walls and dabbed on to brick/block) in a new extension and it appears to be drying very fast. Can I rely on it appearing uniformly dry to paint or should I wait longer in case there is moisture trapped that isn't visible?
FYI plasterboarding has been done over the last couple of weeks (multiple rooms).
(nb. using UK terminology here as that is where I am based - unsure if it is different for USA and things may be done differently there)
