I am about to install a Dryer by mounting it on the wall in an inverted fashion, and then venting it through an existing dryer vent setup that has been designed with a duct joint that goes into the ceiling, and then there is a pipe that leads out of the roof to a roof vent. The two aren't connected, so that means air from the dryer would also circulate around the attic for a bit before finding it's way into the pipe leading to the roof vent.
From reading it seems that this would be bad practice and a potential fire hazard. There is insulation and other roof materials in there that would get exposed to this air.
My goal is to link the aluminium duct (semi-rigid) that I am going to buy directly to the pipe leading to the roof vent. However the way the roof is designed I can't get access to this well enough to attach it properly using a worm ring or metal duct tape.
The current setup looks nice, and I assume was used before with a dryer, I would like to know the risk of letting the air circulate somewhat in the roof area that is vented to the outside (but not sealed).
Or would anyone have any ideas on how I could attach the ducting directly to the pipe leading to the roof vent, thus eliminating any contact with the roof materials/insulation at all.
Ceiling - duct joint that leads to the roof cavity
Inside of duct joint, and pipe to roof vent you can see about 5 cm away
