One of the burners on my glass range stopped working. More specifically, it won't turn on when I turn the knob, but it does warm up when using the Simmer Select setting.
I lifted the glass cooktop to take a look and one of the connectors looks a bit brown. See picture.
Could that be the culprit, or is it more likely the switch?
Stove burner connectors
    It is a touch dirty, but doubt if that is the problem.
    May 17, 2022 at 23:03
  • Thanks. I guess I'll order a new switch.
    – ameruck
    May 18, 2022 at 16:04
-1
I would replace that box with the wires going to the element if possible or it and the element if its connected and cannot be removed from the element. It looks like it has overheated there at one time. That box looks as if it is a resistor pack to allow the different stages of heat and that's why you're only getting low heat.
    "a resistor pack to allow the different stages of heat"...? That's not how stove burner heat settings work.
    – brhans
    May 18, 2022 at 2:13
