First stop is the UL Listing.
Make sure the machine has a UL, CSA or ETL listing, or other Recognized Testing Lab required by your country.
Why? There's a lot of cheap junk out there sold mail order which is not safe, not well made, and not legal for sale or installation in this country. That stuff will not provide satisfaction in the long term, and is best avoided.
I mention this because sticking a 120V plug on a 240V appliance is the kind of "don't care" mistake we see a lot of on cheap junk mail order products. Buyer beware!
Presuming it is listed by an appropriate lab, the instruction will also have been approved. It is important to follow them, as they are the basis of the testing, approval and warranty. Perhaps the control box is powered separately from the pump.
32.8' Cable 4" 220V 630'
means. Usually the'
mark indicates feet, however, I'm not sure I understand how that impacts the numbers you've provided. Also, what doesCable 4"
mean? The"
usually denotes inches - is something in a 4" conduit? Is the cable 4" around? Does the"
note denote inches in this case? The more you can clarify the more likely we are to be able to help you.
