There is a small retaining wall on my property, made of wooden blocks. It is slowly deteriorating, so I had an expert come to check it out: they said it would be good for at least another 10 years, but likely would have to be replaced in the following 5 years after that.
Could it possibly be a good idea to plant trees right above the current wall in the hope that by the time the wall starts to be in need of a replacement, the trees' roots are deep & strong enough to fill the same role and prevent erosion?
