TL;DR: For a four-storey New York brownstone with flat roof how should the dividing parapet wall be covered/sealed?
The brownstone has a rubber-like membrane on the roof that is connected to brick parapet walls. The parapet walls have flags of stone on top of them. These stones aren’t in good condition and parts are flaking off in places. I think it is likely water is getting past the stone and going behind the membrane. In some places I see blisters in the membrane beneath these stones. One of these blisters recently cracked and caused a leak which I fixed with flashing cement and roofing fabric.
My neighbors’ roofs have different treatments.
  • Some have this wall covered in cement and painted
  • Some have clay coping tiles that look like they are designed for this application
  • Some have a sheet metal covering
  • Some have cuboid blocks similar to mine but they appear to be concrete instead of stone
My questions are:
  1. Should be worried about the way my parapet wall has been capped?
  2. Is the condition of the capping stones the likely cause of the blistering? If not, is there something else I should be looking at?
  3. How should the parapet wall be capped?
  4. To keep water off the place where the membrane joins the wall I am thinking of adding inverted U-shaped aluminum flashing over the stones held in place with flashing cement. Is this a sensible solution?
View of roof with dividing parapet walls My roof showing the stones capping the parapet walls
Closer picture of wall Close up showing the condition of the capping stones - stone is flaking off
Blistering Blisters in the roof membrane at the parapet wall
Neighbor's wall Example of one of my neighbor's walls with clay coping tiles
  • I'd guess that the issue is more that there's been a failure in the sealing between the capstones on your walls and the membrane than there is an issue with the fact that stones were used instead of another material. Is the silver actually some sort of (painted?) rubberized material, or is it built up layers of tar/asphalt roofing material? What does it look like where the top of the sliver layer meets the bottom of the capstones?
    Sep 14, 2022 at 12:39
+50
My roof is extremely similar to the last picture. So similar, in fact, that I suspect I know where you live.
The way these roofs work is that that the roofing membrane forms a U shaped bathtub that conducts the water to the scupper at the low end.
The capping stones provide a semi-impervious cover for the exposed top of the walls, and, if done correctly, provide a drip edge so that the water drips off into the bathtub, and doesn't get wicked along the wall. They don't need to be perfect, and shouldn't be, as you want some possibility of having water evaporate out of the wall. There's a whole theory that older lime mortar was better than portland cement because it could handle being wetted and would expand and contract without cracking, but that's another discussion.
In any event, the walls were not really designed to have the entire parapet wall be watertight, and, what you are likely seeing is that some water got behind the wall and is causing it to blister. You will notice that on the terra cotta cap-stone roof, the membrane only goes up a certain distance and is held to the wall by flashing that is caulked -- this joint is protected by the stand-off of the capstone.
How that water got behind the wall could be due to a variety of things...
  • excessive snow followed by rain or a thaw -- this can cause the water to spill over the bathtub
  • driving rain at an angle
  • a "fish mouth" bubble in the seams of the roofing material
  • water coming from the other side of the party wall for the above reasons
  • gap between the coping stones that is wicking water into the wall.
  • a small puncture or nail hole in the membrane that only gets exposed in high intensity rains
  • a temporary blockage in the drain that caused the water level to be higher
As an FYI, figuring out the cause of these issues is incredibly hard as the water can travel under the top layer and come out elsewhere. The roofing companies are notoriously expensive (thanks NYC Scaffold Law!), and, at least the last time I called one, they asked if I spoke spanish and offered me a position as foreman.
In any event, those coping stones look fine, and even if they weep water it is unlikely that that is causing the leak you experienced -- look for sources of bigger amounts of water.
  • Thanks for the answer. One clarification - the leak was caused by one of the blisters which cracked (which I then fixed). So my concern is not so much the water that is getting behind the membrane itself (small volume) but that the water causes blisters that can crack and turn into bigger leaks. You said that the stones should provide a dripping edge to guide water into the “bathtub”. The stones are pretty worn so they don’t have that sharp edge. That’s why I was thinking of adding the aluminum flashing (q4 above). What do you think of this idea?
    – jweob
    Sep 18, 2022 at 16:29
  • Those blisters are really minor. But if you look at the bottom, it looks like you have some sort of nails/bolts popping through at the bottom joint where the horizontial plane meets the vertical plane. If that joint fails, you'll be draining a huge chunk of your roof through that. I had a leak at the scupper where the membrane was loose and on high water days, the water would flow backwards under the membrane and dump through the ceiling. hate to say it, but invest in a really good raincoat and wait for a torrential rain day and bring a flashlight and a helper to shut the hatch.
    – gbronner
    Sep 19, 2022 at 3:08
