We have a wire the goes from Breaker > 2 switches.
first switch goes to a recessed lighting above second switch goes below to an outlet under the sink in a cabinet that controls the garbage disposal, which is the only thing connected to that outlet.
The outlet is currently a standard outlet, and I want to replace it with a Decora GFCI since it's under the sink.
The 2nd switch is going to be connected to a GFCI is that is basically off 99.99999% of the time. The only time anyone turns it on is because they accidently thought it was the overhead recessed lighting switch.
AS FAR AS I KNOW. There are no other lines on the circuit connected to this outlet. I've looked and looked and looked and found nothing else.
Picasso
