My ceiling light/fan in my master bedroom and master closet light quit working (both powered by separate light switches), but the rest of the outlets/lights work that are connected to the same breaker and the breaker was not tripped? Any suggestions?
New contributor
Norma is a new contributor to this site. Take care in asking for clarification, commenting, and answering.
Check out our Code of Conduct.
2Are they getting power? you did check that both lights are still good? Unusual for both lights to burn out at the same time(but not impossible), would check for broken/loose wire in the circuit. Turn off breaker and check switches/outlets and maybe lights.– crip659May 13 at 18:39
Add a comment
