I just recently pressure washed my cement pond, acid washed it and cleaned it with TSP followed by rising it out several times with fresh water.
After this and letting it dry, I primed the pond with an epoxy primer followed by an acrylic paint.
The pond looked great for about 4 weeks. I noticed my water was getting very low (I have some sort of leak and this is something that I'm troubleshooting that I don't believe affects this question).
I did some skimming of the pond since I hadn't in a few weeks and then proceeded to fill the pond up with fresh water.
2-3 days later my pond is a yellow / brownish tint. I was surprised since I just put fresh water in it, but even more surprised when I found it is is the actual paint that is holding this color. It doesn't rub off. The actual paint is now discolored.
What would cause this and how do I go about fixing it / preventing it in the future?
Needless to say, I'm quite frustrated after spending all that time prepping and painting the pond just to have it is now discolored / stained less than a month later. Additionally, very surprised that this happened only after I put fresh water into the pond. It was not stained before I added water.
You can see in the pictures below the original "white" color.
For reference, here are the products used:
- Primer: https://lesliespool.com/smart-seal-rough-prime-primer-1-gallon/26649.html
- Paint: https://lesliespool.com/smart-seal-aqua-seal-acrylic-pool-paint-1-gallon-white/26650.html
Note: The color white was chosen because darker colors warmed the water which make it nearly impossible to keep it from become algae ridden without constantly tending to it. I do not have time to shock and clean my pond multiple times a week. It's just not reasonable for my lifestyle, so I wanted something low maintenance that wouldn't be as affected by the direct sunlight warming a dark / black bottom. I realize it is an atypical color
Update May 21st 2022
The discoloration has largely gone away except for the areas that are now above the water line (due to evaporation). Essentially, everything covered in water has returned to a "white" color. What's weird is that the coloration is something I couldn't rub off, brush off, etc. It was very much penetrated into the paint color, but now it's simply gone.
