When trying to install privacy film on a window such as this one. It seems like I need an installation kit. Most of the things seem simple enough to find alternatives for. However, the solution for spraying on the window before applying the film is more of a challenge. Should I use simple window washing spray? Just distilled water? Soap water?
EDIT
As pointed out by Ecnerwal this film is adhesive film. Perhaps this matters.
The film came with no installation kit. It turns out that's sold separately. My question is how to create an alternative solution for spraying on the window before applying the film. This is needed per the instructions, in order to be able to smooth out bubbles. I don't want, however, to use something that will interfere with the film adhering to the window or somehow dissolve the film itself.
10
    You linked to an adhesive film. That's entirely different from a static cling film (where you'd use water, per the directions, on the static cling film I used.) Adhesive films are a pain in the rear because the window typically has to be clean and dry and you only get one shot to put the stuff on straight. In any case, follow the manufacturer's installation directions since making it up as you go is likely to cause problems. The fact that a shopping site urged you to buy a kit with a spray bottle does not mean the film you linked actually needs a spray solution.
    Commented May 3, 2022 at 14:13
    What do you want us to tell you beyond what's in the instructions for your product? Are you out of the supplied solution? Did you find a box of film without any solution? What's the real problem here?
    Commented May 3, 2022 at 14:15
    I know the film I bought came with tools (squeegee, etc.)included. Not fancy ones, but adequate. As for wetting the window, instructions merely wanted it wet - "spray" was not requested nor required.
    Commented May 3, 2022 at 14:31
    Use distilled water with a drop of dish detergent or baby shampoo to break the surface tension and allow more uniform wetting/spreading.
    – dandavis
    Commented May 3, 2022 at 19:17
    If you don't buy the kit, you'll lose all warranty benefits. Follow the manufacturer's direction.
    – JACK
    Commented May 3, 2022 at 20:42
I have installed that exact same product on many windows in this house and my previous homes. I always just used water with a little bit of dish soap in it.
The cleanliness of the glass before you install is a lot more important that which liquid you use to apply. All it needs to do is keep the adhesive from sticking for long enough for you to position the film and press the bubbles out.
