I will be adding a ground to an existing 3-wire setup in oder to make it safe and code-complaint. Will the new bare Cu ground wire use the same receptacle knockout (bottom) as the Al jacketed 3-wire, or will it have to be clamped from the back via the other knockout?
enter image description here Is it OK to have exposed bare ground (4th-wire) for a short run behind/under the range? enter image description here
  • I have a feeling there will be only 1 clamp provided per receptacle.What type of clamp do I need to get for a bare #8 or #6 ground wire
    – Matt
    Commented May 2, 2022 at 19:51
