Friend wants ceiling fan/light unit installed in existing fan-rated box, which only has one circuit. That is, there is 2-wire romex coming to box, and a switch leg going to a wall-mounted switch. Thus, available in the fan box is: neutral, hot, switched load (from the switch leg).
They would like to be able to control the light from the wall switch, and the fan using the remote. I believe this can be done with the following wiring scheme:
Note this is exactly the way a fan remote is shown to be wired in the instructions, except (as shown with the 'X') I would not connect the "light" output of the remote-receiver to the fan, but rather connect it to the switched load signal.
Is this acceptable ? The only way I can imagine it causing problems is in case there is some kind of interaction between the light and fan circuits in the fan assembly; this seems pretty far-fetched.
