Originally my son's fan was wired so that the 1 light switch he has in his room turned on the fan's light then the pull cord on the fan turned the fan on separately, even when the light switch was “off”.
I actually just changed the fan so it operates on a remote and was hoping to return the switch to just doing the 1-way where the switch turns on or cuts off all power to the fan.
When I installed the fan, I used the wires that I had disconnected off the old fan. I capped grounds together, black to black, white to white, capped off the blue wire that came on the fan, then capped the red wire (which I figured was the solution here since we didn’t need that separate hot).
I opened up the light switch and I’m seeing both black and white wires, together, on the top nut of the switch then the red wire pushed into the bottom slot of the switch.
Is there another way I need to be wiring the switch on the wall? Or is there something I need to do to the fans wiring?
