My tenant just moved out and I discovered the washroom grout is extremely moldy. It ate away the grout. May I may get suggestions on how to possibly fix this?
    Usual suggestion is to remove, clean and replace. With mold probably want a good wipe down with bleach first.
    Apr 17 at 16:15
    ...and improve ventilation to prevent recurrence.
    Apr 17 at 16:27
  • Use hydrogen peroxide to kill mold it actually works better 3% with water works well since you have white peroxide will help to remove the dark coloring also.
    Apr 17 at 16:40
  • One of y'all should write that up as an answer so the question can get an accepted answer and not be bubbled to the top by Community for the next 5 years.
    Apr 19 at 12:36
