I'm scouting to setup a home surveillance system for the grounds. The grounds are overgrown with shrubbery, ivy, and trees. The former two I shall address; the last I can not. The best location I can come up with for cameras is atop a 20' 2"x1" Mild Steel angle (nominally 18' as 3' will go into the foundation). The distance in a straight line to the boundaries of interest are around 60', 100'.
My concern though is running CCTV 3+1 cables from this pole to the house which is around 50' from the pole (68' from the camera) where the DVR will be. I can probably mount the power-supply in a weatherproof box on the pole itself but the video-out will have to reach the main structure which is quite some distance i.e. 88' or better.
How far can a 3+1 CCTV cable carry video effectively ?
  • 9
    Why are you doing anything but Ethernet + PoE for video surveillance today? Ethernet can handle up to 100m, and in practice even a bit more.
    – vidarlo
    Commented Apr 8, 2022 at 9:06
  • 5
    Got the data on the cable for attenuation in dB/km? also +1 for ethernet
    – bobflux
    Another + for Ethernet getting a modern setup will be much better in the long run 300’ is a no problem I have run 300v cat V with power for close to the entire run and had no issues with high res cameras.
    Commented Apr 8, 2022 at 15:22
  • The thing with ethernet is ... utter novice here- I reckon ethernet means IP Camera. That pushes the costs up enormously
    – Everyone
    Commented Apr 17, 2022 at 13:00
Quite a bit further than 88', if the cable is decent. CCTV is baseband video (below 6MHz) rather than RF, so the loss of ordinary RG-59 is less than 1db per 100 feet.
