We're converting some of the attic space in our garage for storage and I'm hoping someone here can help with some concerns I have about the work that was done. I'm handy but not in construction and have only learned the little bit I know about framing recently in order to figure out this issue, so I apologize in advance if my description isn't clear or I've missed mentioning important info.
We didn't want anything fancy, and figured some plywood on top of the rafter ties would be fine as long as the framing was reinforced to support the weight of our storage. A contractor that quoted the job (but that we didn't hire) said he would add two more rafter ties so the storage area would have them spaced 2' apart and that should be enough to put plywood on top of for storage. But the handyman we ended up hiring instead put 2x4s to connect the existing rafter ties to each other and left them 4' apart. He did attach 2x4 along the wall with the garage door parallel to the rafter ties and attached it to the next rafter tie in the same way, using 4' boards.
We assumed the handyman we hired had a good understanding of framing based on a recommendation we got from a neighbor and a quick look at his work. He definitely was fast, and had done 60% of the job before I saw the technique he was using.
I asked him to put more support in between the rafter ties and I expected he would remove the perpendicular boards he put in and put in continuous/lapped together boards. But instead he cut more 2x4s to fit in between the boards he already put there and added them along the underside of the OSB plywood sheets he already installed. Text
Unfortunately, I don't know if this is OK or a real problem. It seems more like a grid/patchwork of boards rather than a properly framed garage ceiling/storage flooring based on the limited amount I've learned recently. I'd like to figure out:
  • if what the handyman built will be strong enough to support the weight of some light storage
  • if what was added will be too heavy/not worth the strength it provides, and increase the chance of failing/falling
  • if this design will put too much stress on the roof
Hopefully the photos will help, but here's a description of our 3-car garage: 26' across, 23' front to back. The ridge is off center, so one side of the roof slope is longer than the other side. The rafters are all 4' apart and are 2x6 on the short side of the ridge and 2x8 on the long side. There are 5 lapped 2x4 rafter ties going across from side to side. Each rafter tie has 3 vertical braces (2x4s), one up to the ridge beam and one slightly more than midway down each side. There are also 2 strongbacks (I think - they're lapped boards that run perpendicular to the rafters, sit on top of the rafter ties, and go from the front wall to the back wall of the garage. There are also 4 collar ties every 4 feet alternating with the rafter ties. The roof is about 15 years old, but multiple roofing and general contractors have commented that it seems in good condition. Text Text
Thanks in advance for any thoughts on this!
Mike
9
    IANAE - but it definitely looks like it's way under-spec'd for just about any significant load (does it feel very springy?) - 2x4 are fine if supported everywhere [which isn't possible in this scenario] but suspended like that I'd be putting 2x12 or 2x15 especially if you're going to put something more than boxes filled with air !!
    – Mr R
    Apr 8, 2022 at 5:33
    I don't see any proper load transfer between those beams, i.e. metal braces. And I would not trust it even if it had, you should at least have a few strong cross beams.
    – MiG
    Apr 8, 2022 at 7:10
    IANAE either, but it looks to me like this roof structure isn't designed to support much beyond its own weight. I would be very leery of storing anything up there. Obviously, it's holding the added weight of the new lumber, and probably a person or two as it was built, but anything more significant than a bunch of EMPTY cardboard boxes stored for any significant amount of time is likely to cause sagging in the rafter ties which, through the vertical tie members, will start to cause the roof to sag. I'd get an actual structural engineer to make a design for you. (con't)
    Apr 8, 2022 at 13:39
  • It might cost a few hundred dollars, but that's far less expensive than having the roof fail in a few years. You've got a lot of space up there and if you're even vaguely normal human beings, that'll get filled with all sorts of stuff that weighs a lot.
    Apr 8, 2022 at 13:41
    The roof with 2X6 on 48"centers and relatively low pitch is likely fully stressed just holding up the shingles; It can't support more weight. Apr 8, 2022 at 14:15
Yeah, this isn't good.
Common rafters are designed to carry load above them. Rafter ties are only intended to be in tension, keeping the walls from splaying. Neither are up to the task of carrying storage in this simple form.
Engineered trusses (or hand-framed trusses with webbing and/or ceiling joists resting on interior walls) spread and transfer loads in predictable ways. Even then, attic storage can overstress them if not done carefully. It's unlikely that your entire roof will come down due to the nature of sloped roofs, but you may see significant sag and other damage, or local failure of the platform.
The primary issue here is that nearly all the platform load is being carried by a couple suspended posts. If they let go it all comes down. They're probably attached with a few nails or screws that are far from adequate. The rafter ties are little more than trampolines at that span. They don't do much here.
I suggest that you get a qualified professional to give you advice. The scope of that is bigger than what I can provide here. It would either involve two or more trusses being designed and installed, or a beam-and-joist arrangement.
However, I prefer a good old fashioned 24-32" deep shelf on three sides of the garage. It gives you nearly as much storage* and can be done much more safely. You have all the material you need already. It's a fun and easy DIY project.
* If you think you need more attic storage, consider carefully whether you just need less stuff.
    In case you accept the advice on perimeter shelving but after searching your soul you determine that more is more, you can combine perimeter shelving with pulley systems like little platform hoists or special ones for bikes, kayaks, ladders, etc. that will make good use of the space up above the doors without all the safety issues of building a platform that can support you.
    – jay613
    Apr 8, 2022 at 16:06
