I'd appreciate some advice on this particular patch job I have to try and finish after my dad had a fall. So far he screwed the drywall patch into some wood pieces screwed to the joists which left it a bit recessed compared to the surrounding drywall, and he applied "instant filler" (not sure exactly what that is) to the gap around the patch and to bring it almost flush with the surrounding drywall. I started applying the mesh tape he gave me earlier but then wondered if it was really necessary given that it will create a very small hump.
I'd be grateful for advice on whether the mesh tape is really necessary in this case. Also he was going to use all purpose "finishing plaster" for the rest of the job, I'm hoping that's okay because I see online there's a lot of discussion about setting compounds and hot muds etc. Hoping I can get away with this plaster he has for what is just a small job really.
Thanks!
Click to embiggen
