I have this wooden transition strip between a laminated "wood" floor and a ceramic/"stone" tile floor. It recently came unglued with wear and I want to put it back on. It looks like they just sort of slapped some wood glue on it before.
What's the best way to reattach the strip? I was planning on just using wood glue again but if there is something better I'll give it a shot.
What do I need to do to prepare the surface? Should I make some effort to scrape the old glue off? Is there a solvent that'll be safe on the laminated wood half?
transition strip and gap
  • Is it a T molding or just flat?
    Apr 5, 2022 at 14:29
  • The transition strip is flat on the bottom
    – ldrg
    Apr 5, 2022 at 17:19
I doubt that's just wood carpenter's glue. It looks more like construction adhesive and that makes more sense for this location.
Gluing is like painting: the quality of the result depends greatly on the quality of the prep work.
Yes, you absolutely want to scrape as much of the old, dried adhesive off both the floor and the bottom of the transition strip as you possibly can. You could even go so far as to sand the bottom of the transition strip to get a smooth, flat surface and even sand back some of the finish on the edge of the floor (only the part that will be covered). This will ensure you've got good surface prep for the adhesive and gluing to bare wood will give you better adhesion than gluing to a finished surface.
Make sure you get the old adhesive off of the tile side of the floor, too. You should be able to chip it off with a scraper blade or possibly an old (sacrificial) flat-blade screwdriver or chisel. That tile/stone looks like it's got a bit of a rough surface, so there should already be a good key for the adhesive to grab onto on that side.
Once you've got the new adhesive down and the transition strip in place, push the strip down, wipe up any squeeze out, then weigh down the strip with some boxes full of books, weight plates, or other similar heavy items. Let the weight sit there for at least the minimum cure time listed on the adhesive you're using.
If the floor is solid and doesn't move, you clean it up and sand it a bit and use flooring glue and weigh it down while it dries, that ought to do it. If there's any movement ie if the floorboard is a little soft or if the strip doesn't rest perfectly on both sides of the transition, I would put in a few brass screws as well.
