I need to install a washing machine drain using a cast iron floor drain. The area is very small, and this is the only drain I can use (I do not own the home so cannot do much about the plumbing). The water heater drain tube is also inches away from this drain. Here is the type of drain I have in the utility room:
What is the best thing to do with these drains when it comes to washing machine drains?
Is there anything like a fernco donut that would be useful here, or anything other solutions short of just pushing the drain hose into the floor drain and hoping it never gets dislodged somehow?
