So, if I understand correctly, you want the fiber to come into your house, then connect to the fiber router somewhere inside the house, without looking ugly on your walls. Then the rest of the house is wired with standard Cat5e or Cat6.
That's what I have done, so here we go.
The guy who will come to install fiber to your house will pull a rather thick fiber cable from the street. This contains a few very thin fibers, with a tough plastic protection sheath around them so it survives being pulled through underground conduits. This fiber cable doesn't have a connector at the end, because that would prevent it from being pulled through conduits. The installer routes this cable to a fiber junction box, then does the junctions, and the router is connected to this box with thinner optical cables. These cables are designed for interior use, so they are quite thin and flimsy.
In a multi-story building, there is usually one junction box per floor, and thin cables running to each apartment. In this case the thin cables can be routed through conduits and walls, because they don't have connectors attached. In houses, they usually put the junction box somewhere easy to install inside or outside the house, then they'll use a readymade patch cable
with connectors attached. The connectors will not go through conduit, unless the conduit is huge, like 35mm, to let the connectors through. And they tend to get stuck, and the fiber is fragile, so it's a bad idea to pull these cables with connectors through conduits.
So, you should check how things are done in your jurisdiction. Look how it was done in your neighbor's houses, and call the installer. If they want the fiber junction box outside to be able to service it, then ask if they can route the fiber through conduits you provide, and make sure the installer will come with the necessary stuff, especially the kit to add another junction box at the end of the interior cable, what kind of conduit diameter you need to install, where it should exit the house, etc.
Then, all you need to do is make sure there is a conduit path from wherever the fiber will come from (on the street) to wherever you want to install it. The tough fiber cable doesn't bend well, it is quite rigid to protect the fiber inside. The flimsy cable breaks when it bends. So this conduit shouldn't have sharp angles.
I'd recommend 20mm or 25mm conduit, it's easier to pull through and harder to bend.
These conduits are usually delivered with a steel wire inside, which is mostly useless, it always gets stuck or breaks. So the first thing to do after laying the conduit is to attach a proper tough wire to it, or a tough PP string, and pull it through.
Then leave both ends accessible, and when the installer comes, just tell him to pull the fiber through it. This needs two people, one pulling on one end, and the other pushing the cable in at the other and making sure it doesn't make any knots, so you'll have to lend a hand.
Make sure you have a roll of PVC adhesive tape on hand.
