I'm building a small Tiki bar in my backyard and already framed my gable roof at 3-12 pitch. All the rafters are plumb cut.
On the front of the structure, the ridge beam protrudes out 4 feet. I want to run a fascia board from the front rafter to the ridge board. This is a 55 degree angle rather than a 90 degree, and the vertical angle from the rafter to the ridge beam is 10 degrees.
My saw only goes to 45 degrees miter. Can someone help me to understand the way to cut these compound cuts?
