Found when cleaning out the garage. It slides to open up as shown in the photos.
Are there any significant markings on it, a company name, or even model number?– MonkeyZeusMar 29, 2022 at 15:34
No markings of any kind including company name or otherwise unfortunately.– JasonMar 29, 2022 at 15:35
1Is that white dust residue on the top of the plates? Maybe you're supposed to stick it in wet concrete and telescope the tool vigorously to bring air bubbles out of concrete?– MonkeyZeusMar 29, 2022 at 15:39
1no indications of wear more than what can be noticed in the photo. no other residue noticed anywhere. It is possible it was never used as well. The only idea I had was it could be used to drag in the lake to remove weeds but that seemed a bit of a stretch– JasonMar 29, 2022 at 15:59
4I've no idea either, but that isn't a very 'grab-and-rough-about' friendly handle. You wouldn't want to be stirring cement all day with a handle like that, you'd want something heftier & no square corners. Having said that, the slide mechanism is going to have a lot of drag in it for a repetitive operation. It doesn't look old enough to be pre-nylon bushes etc if it were. That leaves me with only one suggestion - Marge Simpson's hair brush. [sorry;)– TetsujinMar 29, 2022 at 17:38
1 Answer
It's a NEUMAN chimney cleaning tool from 1929
This chimney sweep tool is shaped rectangularly to match the inside shape of the chimney, and the expansion adjusts to match a range of chimney sizes.
To convince a spouse to keep it, you can rebrand it as a uniquely re-purposed flower stand:
Value $103
Link: https://www.etsy.com/listing/838043669/vintage-orange-chimney-sweep-sweeper
and https://www.worthpoint.com/worthopedia/vintage-chimney-sweep-cleaner-scraper-173534122
No additional brushes or bristles are needed. The zig-zagged bottom is the brush. According to its 1930 patent, "The lower ends of the scraper bars terminate with transversely disposed fluted portions 6, which portions form contact brush elements for engagement with the four walls or" the chimney."
More details in the patent, at https://patentimages.storage.googleapis.com/bf/ca/9d/c4c933a9e6bf2c/US1775969.pdf
4...So, would this have had some kind of brushes attached to the ends of those zig-zaggy things? Or did you just scrape metal on brick directly? Mar 30, 2022 at 13:35
7@DarrelHoffman I imagine it would be used as-is to get the bulk of the soot off the inside of the chimney. Then you can use a brush if you don't think there is already enough mess everywhere, from my limited experience cleaning a chimney above a coal fire. Mar 30, 2022 at 15:47
Did the etsy seller that you linked lower their price from $103 to $79 since you posted or why are you saying value is $103? Mar 30, 2022 at 17:18
@DarrelHoffman according to the patent (see above, I added) the ends are the brush.– P2000Mar 30, 2022 at 20:22
6This was a good answer and got my +1. Now with the link to the patent, it's an even better answer, but I can't give it another +1. Please accept this pat on the back instead.– FreeManMar 31, 2022 at 12:57
