I am attempting to install a new circuit from a subpanel that is a 20A, that will have 4 outlets and 3 lights.
From my limited understanding of how circuits are wired, this are typically done in series. A wire goes to the first outlet, then the second, and so on.
However, in my case, it would be very convenient to do kind of a junction box above the subpanel, and go right to wire 3 of the outlets, and left to wire the remaining outlet and the lights.
Is this kind of thing allowed? What is the proper term for this, I am having issues doing a search online.
This could obviously be solved by doing two different circuits, out of the subpanel but that seems kind of overkill for the load.
