I have a concern and a question about the same structural studs. If it matters, I am in Ontario, Canada.
Firstly, as you can see in the picture, the three 2x4 studs are holding up the four 2x8 beam above. Right below in the basement, there is a metal I-Beam running parallel to the beam you see in the picture. Above the drywall cut, there is a vent pipe running straight through these studs, removing a good chuck of these studs. When I pressed on the studs near the vent pipe, the studs would bend but then relax back to its normal state. Also the vent pipe is not being compressed as far as I can see. They did put some metal plates to prevent drilling through the vent pipe and I would assume to add strength, but these plates are not really attached that well as they are loose. I am making the assumption that there is not that much of a load on these studs. Is this structurally safe?
Secondly, I am redesigning the kitchen and have to move the stove to the left. The new exhaust vent for the range hood unfortunately lines up right in the middle of those 3 structural studs. Is there anyway to cut the hole in that spot and still keep the structural integrity. For example, adding a quad joist hanger to the beam, plus adding double 2x6 header just below the double top plate and redistribute the load around the vent hole?
Any help would be appreciated.
