Not a very important question, but I'm wondering what the little diamonds are on my tape measure. It's a Stanley Fatmax from the UK © 2011. The first one is at ~488 mm (~19.2 inch), and then every ~488 mm after that along the tape, but they don't align with any regular measurement in can fathom.
1 Answer
It is an alternative framing spacing, used for studs, joists and rafters. It is an "identifier" for a stud layout much like the 16" center layout where you will get an even amount of spaces over an 8 ft. piece of material, or for that matter a 16 ft. piece of material as well.
1In other words, instead of 6 studs per 8' span, you get 5 joists for the 8' span.– BMitch ♦Mar 25, 2022 at 12:49
1@FreeMan — it varies from place to place, but those are usually drawn by architects that hate carpenters ;) Mar 26, 2022 at 22:47
I have used those center marks myself. I was building an outbuilding using 2X6 oak salvaged from a barn, and needed to adjust my framing to work with the material I had. It worked out pretty good for my occasion.– JackMar 27, 2022 at 18:45
