I have 3/4" furring strips over concrete wall. I'm putting 3/4" plywood atop the furring strips. This is inside, covering a basement wall.
Will 1 1/4" screws be long enough to attach the plywood?
1 1/2" wood screws would be optimal, but the local hardware store didn't have any. Also, I can imagine the tips might hit the concrete and prevent the heads from sinking in a small bit into the plywood.
I can try it and see what happens...don't necessarily need to ask, I suppose. But, because I often get good ideas/thinking here, I thought I'd post.
