My 20 year old steel bathtub is making weird noises when pushing on it with my hand (probably like what, maybe 10-20 pounds of pressure?) and when standing on it, the noise seems to originate around (but not directly on) the drain, does anyone know what it could be?
I'm just a simple homeowner without plumbing experience so I have no idea what could be wrong here or if anything needs to be done, or if there's any safety risk or anything?
Here are the noises: https://streamable.com/em723p
Here is a picture of the tub: https://i.stack.imgur.com/9o82P.jpg
Thanks in advance for taking the time to read this.
10
    So it sounds like it didn't have a proper base or it didn't have a base or the base wore out after 20 years I guess. Is there any problems with leaving it the way it is or is it fine? I'd rather leave it alone if there aren't any safety or other concerns the way it is.
    – JS99
    Mar 20, 2022 at 0:10
    If it's moving with only 10 kg pressure, you might check if water seepage has led to extensive rot under the tub. Filling the tub with water might lead to its descent into the room below. Mar 20, 2022 at 3:36
    Joists can rot as well, if that's what's going on here. They are not immune to rot by reason of being joists...
    Mar 20, 2022 at 13:44
    If there were rot bad enough to affect the joists wouldn't there be any signs of water damage like the ceiling being stained? I'm not sure I've even used this shower enough for there to be any rot, I used the master bathroom shower for years and only started using this shower the past month or so and not even super often at that. How would I know if there's rot vs the base layer underneath the tub just wearing out after being 20 years old?
    – JS99
    Mar 20, 2022 at 14:33
    Another reason I think it's probably not leaking is just today I looked at the drywall directly underneat the tub, and it's perfect, bone-dry looks brand new no stains or anything even though this house is actually like 20 years old lol
    – JS99
    Mar 21, 2022 at 22:24
