I currently have an Intermatic timer switch on my lights, and I would like to add a dimmer switch next to the timer switch, because the lights are sometimes too bright, is it possible to have both a dimmer switch and a timer switch on one light?
The dimmer switch: https://www.amazon.com/dp/B0771BC2YH?psc=1&ref=ppx_yo2_dt_b_product_details
The Intermatic timer: [1]: https://www.amazon.com/gp/product/B003A3V03A/ref=ox_sc_saved_image_1?smid=ATVPDKIKX0DER&psc=1
also will the dimmer switch interfere with the timer
    Should be possible. Think you need the timer first in circuit then the dimmer. Dimmer might make the timer wonky if the dimmer is first.
    Commented Mar 10, 2022 at 21:39
Tough question. The issue is the problem of "dimming the timer".
If it is a hand-crank mechanical timer, like the classic Intermatics, then it doesn't matter since the timer is a "dumb" on/off switch powered by you. I would put the dimmer first, and dim the timer, because I can comfortably say virtually every dimmer is OK with that, and will remember its brightness between uses.
However, if the timer has any internal electronics, or takes a neutral wire, then it needs to be first. You can't dim a device with onboard electronics.
  • Hey Harp. I'm surprised you said to put the dimmer first. Whether electronic, mechanical motor driven, or hand crank, I would think they'd expect line voltage. I see no point in putting the timer behind the dimmer. I certainly agree with you regarding electronic timers. Commented Mar 11, 2022 at 0:57
  • @GeorgeAnderson -- a wind-up timer only cares about the electricity supply insofar that its contacts are able to safely switch the voltage given to it Commented Mar 11, 2022 at 2:06
  • @George I have a wind-up timer on a 240V line. They are just a dumb switch and don't care. There is a minor cost to putting the dimmer downline of the timer: it will tend to lose its internal settings if it has any. Commented Mar 11, 2022 at 3:19
