I have an heavy duty office chair for my work-from-home (I am very obese). About every month, one of the bolts falls out of the arm. You can reattach it with a hex-head allen key, although it takes a bit of effort and fiddling, as often the bolt seems to rotate without 'binding'. The bolt is circa 30mm long.
I am wondering what options I have for fixing this in the long run? I think eventually it will be unfixable because I will have damaged threads. If the arm can't be fixed to the chair then the chair is useless as the arms hold the back up, and the chair was quite expensive.
