There is one answer to your question highlighted with 4 upvotes (at this time) that is extremely "Tiger Mommy".
Yes, you can do an epoxy shower floor but you need to reinforce the substrate with fiberglass mesh. I have done this.
- First you prime your substrate. Use a high-solids flat paint or a marine paint.
- Then you pour a bond coat of epoxy and lay the fiberglass mesh on that. Work the bond coat into the fiberglass mesh until the fiberglass gets a little bit translucent.
- After that is set, you are ready for your build coats of epoxy. You can paint over a sanded bond coat or dye your build coats for color or translucency (most people don't find fiberglass mesh attractive).
- To maintain your slope you should let your epoxy start to set a bit and that way it won't flow too much. It's still going to want to flow when you torch the bubbles but use your v-notch trowel to bring the material back where you need it.
- For this application you will probably need to add a grip agent in the final coat. Leaving a pure epoxy surface will be slicker than snot.
Don't be afraid to experiment. After all, you will end up with a water proof shower. Your patience and determination will prove out the results.
