I'm doing a bathroom reno in an old house - all copper pipe, and no shutoffs. There is a single shutoff between the well pump and the pressure tank, and another shutoff between the cold water input and the hot water tank.
I need to move the inlet piping for the shower. It looks like this has already been done once (why people don't add shutoffs is beyond me), however this requires connecting to a live pipe.
My current solutions:
- Kill water to the entire house. Use it until pressure is low, then open the shower tap and a tap lower than it to back-drain the water out of the piping. This is less than ideal because it means the entire house must be shut off, I have to kill the hot water tank (to avoid burning out the element) and it must remain in this state while I go to the hardware store for the inevitable part I didn't buy the first time.
- An expensive inline valve. It looks like there are solutions to this (valves that clip on, and cut the pipe), however they're expensive and I'd like to avoid permanently relying on what feels like a stopgap solution.
Are there industry-standard methods of doing this? I know the bread in the pipe method stops stray water flow, but I don't think it works against 40+PSI of hot water.
