I am trying to replace an old faucet that my 3 yo child is unable to use because of its design. I'm new to plumbing but actively reading. I haven't seen these supply lines w/o valves before. This looks like the pipes are going straight into the faucet. This is an '86 built property in Canada. I tried to look through the vanity base but didn't find a valve.
Its a fatter pipe which gets slimmer as it enters the faucet.
- Ideally I would like to add valves and then modern braided pipes into a new simple faucet. Is this doable and wise?
- What tools will I need to achieve this - I have a wrench, channel locks and the basics. I think I'll need a pipe cutter and something to smooth out the freshly cut pipe. Any solution/paste?
- What hardware will I need to purchase - if it's a 1/2" pipe, can I use any straight 1/2" valve?
- Is a modern faucet built to the same standard that modern valves and pipes are built to?
- How can I make a secure seal w/o using a soldering solution? I read this is where compression valves come in.
Pic of work area:
Pic of faucet inside:
Pic of view from under sink:
(1)
of everything. Still no tubing cutter nor PEX cutter (those can be pricey) that the OP will need. If that does include 2 of everything it otherwise looks like it might be a fair deal.
