For purposes of laying out a quilting project, I want to use an approx 4' by 7' wall space. I have a large piece of thin fabric that is tacky on both sides. One side goes against the wall and stays there. On the other side, I place small blocks of fabric for a quilt, rearranging them until I've found a pleasing layout.
The tacky fabric needs a smooth wall surface. My painted and textured wallboard is not smooth enough. I could use additional spray glue, but I don't want to spray that on the wall, as it may be difficult to clean up when I want restore the wall to its original condition.
I think the solution is to mount another board on the wall, attached with appropriate anchors. I could put up gypsum board/drywall, but what other board type would be better? Something really smooth and thin would be best.
  • Why not just sand the texture down and repaint, cheaper and easier than putting more material on the walls. at my last home I had a huge projection wall that was glass smooth with the glass beads in the paint. Around the outside I put some trim it looked like a giant picture frame. You could do the same using a gloss paint that would hold the sticky fabric.
    Feb 19 at 18:19
  • @EdBeal Thanks for the suggestion but I don't want to permanently change that wall. Feb 19 at 18:26
You could obtain a 4'x8' piece of coated hardboard and hang that on the wall. (You could also build a frame for around it as Ed Beal suggested in his comment.)
The hardboard has a smooth, white, glossy acrylic surface for the tack cloth to stick to, and is thin enough to still be lightweight.
You can pick one up at a BigBox store for about $20.
  • Some hardboard comes in brown but is still very smooth. (Just in case OP can't find white, the brown stuff should work, too.)
    Feb 19 at 22:05
  • True. The brown stuff doesn't have the same surface coating though and that coating might be a good idea for moisture resistance and durability, etc. I think you're right tho. the brown should work too.
    – gnicko
    Feb 19 at 22:10
  • Terrific. Just the kind of response I was hoping for: a specific kind of product that I was pretty sure existed but didn't know how to search for" "smooth wall board" didn't get it. ;) Feb 19 at 22:18
A sheet of plywood either 3 or 5 ply would work.
Have to fill screw holes after though.
