I bought a glacier bay laundry sink from home depot for $200. The instruction manual says to glue the sink to the cabinet with silicone. So I did that as you can see in the picture. However, the cabinet is screwed to the wall behind it, and the screws are behind the sink basin inside the cabinet. I want to unscrew the screws, however there is no working room behind the sink basin. Therefore, I need to remove the sink.
How do I do that? I tried pushing the sink up from the bottom, but it's held on VERY tight.
Now I see the poor engineering in the instruction manual where it tells you to put screws where you can't access after installing the sink, and the sink itself is extremely hard to remove…
