I have to replace toilet seat in small space and not familiar with this tightening screw. I tried using pliers to pull it down but obviously need to remove the nut first. Any advice what tool to use to remove this?
2I've not seen that type of attachment but if I had to guess, I'd say use the pliers to pull out the horizontal cylinder which seems to be attached to the two prongs. I expect that that would release the squarish ring.– DoxyLoverFeb 17 at 6:40
Haven't seen this one before either, and unfortunately your photo is quite fuzzy. Is the threaded part of the rod above or below the ring?– MiGFeb 17 at 7:06
6Are you sure there's not a way to attack this from above... like a screw head at the top... maybe under a plastic cover?– JACKFeb 17 at 13:20
1That looks a lot like a kind of "molly bolt" which is intended to be screwed & unscrewed from the top, as if the nut on the bottom is inaccessible. You probably won't be able to turn the nut as there's not enough space under there - you'll have to attack it from the top.– brhansFeb 17 at 15:08
1Sure is a tough one. Thanks for the suggestions guys. I will try suggestions but this does seem like unique fitting.– Jan PeeterFeb 18 at 9:11
1 Answer
The connection seems to be a lot like this: https://www.guillens.com/buy/product/0061761000/450265
It looks as though the toilet seat pulls off, just held with O-rings and it exposes a space for a spanner to counter-clockwise turn the bolt out.
Yep that is exactly what I have. Issue is I can't hold the top part since the toilet seat covering it. Will try holding it and see if I can turn it somehow. Feb 25 at 12:15
I think it is required to remove the seat. Guessing the original install method would be to bolt on the bolts to the toilet bowl and then press the seat on afterwards, probably clicking into grooves inside the seat holes.– ChrisFeb 25 at 13:14
That is correct Chris. I finally got it off, just had to use my superpowers and inspiration from this video: youtube.com/watch?v=ZKq0DCUAduI Mar 23 at 13:34
