TL;DR: Can this be wired up to work?
More images: https://imgur.com/a/qQcZXpL
(You can't tell because of the flash--but the two browns that connect next to each other on the thermostat are just slightly different shades.)
One comes from inside the fridge and the other from the light switch. Darker on the right, lighter brown on the left.
The 2 brown wires that go at section 3 only has 1 terminal here.
And single black cable that goes at 4 has two terminals.
I've tried looking for my exact model, but they all seem to be this type with alt terminals.
Story: (The fridge is acting up. Originally it was getting far too cold on 3(n) dial setting--that is normally fine for this time of year. I had to turn it to 1.5 to reach ideal temps. Move over a few weeks and now it's the opposite. It isn't getting cold enough, although it still frosts at the top back.)
It seems to sound like the compressor is always on. It's quite random. Ice is melting atm. Very random.
Since I need a fridge pronto..I chanced buying a replacement thermostat. I don't think that's the issue, but it's worth a try I suppose. Only I've opened the package, and my fridge only to notice it differs slightly.
What do I do? Thanks.
(UK)
