I'd like to move drain on the left to the side of the joist to accommodate for off-center Schluter shower tray. Is it acceptable to do in current setup?
If not, can I cut shower tray 5" from the side of the drain to accommodate for current position of the drain which 5" from the wall? Schluter shower drain is 10" from the left side.
Edit: Proposed solution
