I’m installing a 60a sub panel in the garage to feed a car charger and serve as the tie point for a portable generator. The garage is on the other end of the house so I only want to pay for 1 cable run, hence the subpanel. what residential interlocks are available to interlock the gen breaker in the garage sub panel to the main breaker in my main panel? All the interlock kits I see are for breakers in the same panel. Thanks in advance
    Well, we can help A LOT with the cost of wire. Are you willing to let go of some wrong superstitions? Feb 7, 2022 at 22:11
  • Have you already put the conduit in the ground? Feb 8, 2022 at 1:13
  • Is the garage attached or detached? Feb 8, 2022 at 2:32
  • "alternative" being a word for "not code compliant, no way, no how" here. Well, you can be code complaint if you only want the garage circuits to run from the generator. See diy.stackexchange.com/a/37031/18078
    Feb 8, 2022 at 13:12
  • I added an answer to the other question. Upshot: lose any superstitions about aluminum wire... and voila, costs fall right into line. Feb 8, 2022 at 21:10
