I think I've made a code violation. I'm wondering how dangerous this might be. I have a 20 amp wall oven and separate 40 amp cooktop wired to the same circuit via a split bolt.
They're wired to a 60 amp breaker. The cooktop is using 6 gauge wire, but the oven is using 10 gauge wire. They join together into 4 gauge wire to the breaker box.
I'm thinking the 10 gauge wire is problematic, given the 60amp breaker. Is that the case? If so, how dangerous is it? If it were to short circuit, it would presumably only go up to 60 amps for a short period of time, right?
Any help is greatly appreciated.
Edit: Both are hardwired.
Oven model: 904.620.39 (ikea adratt)
Cooktop model: 704.620.64 (ikea samfalld)
