The tube, which I bought in December 2021, says
Batch 21E11
Expiry 05/2023
I'm taking this to mean that it was produced one month before purchase, and at this time still has 15 months before expiry.
I cut an ample hole and, one minute later, squeezed, but it protrudes from the wrong end, as you see in the picture.
silicone will not exit
What might be the cause of this? Does it mean that it has solidified near the nozzle end?
    Cheap latex you might not have to poke. But always with 100% silicone.
    – Mazura
    Feb 4, 2022 at 7:00
  • @Mazura Does the cheapness of the latex correlate with the durability of the seal?
    – MonkeyZeus
    Feb 4, 2022 at 15:10
  • Looks like you have your answer but this can also happen if the nozzle gets badly clogged.
    – JimmyJames
    Solvent-based caulks (silicone, urethane) tend to have a seal behind the nozzle. Water-based caulks (latex, latex with silicone) usually don't.
    Feb 4, 2022 at 15:25
  • In manufacturing, it's much more common to label manufacturing dates with year and the week in the year rather than the year and just the month in which the product was made. Thus, the 21E11 is much more likely to be the 11th week in 2021 (e.g. perhaps batch "E", week 11 of 2021) than it is to be the 11th month in 2021. However, there's nothing that really says that "Batch" number includes a human-readable date code, even though the 21 tends to lend itself to being interpreted that way (i.e. it's quite likely to be a date code with a batch within the date, but we don't actually know that).
    – Makyen
    Feb 4, 2022 at 19:40
22
Did you cut the end, but not poke a hole in the seal down the nozzle at the end of the main tube?
That seems like the most likely reason for the set of things that happened here. Many caulking guns have a pin for the job of piercing that seal built onto them. Otherwise you need a stiff wire or long nail for it.
10
Most, if not all, caulk guns are equipped with an "opening rod" for breaking the seal in a tube of caulk, silicone, or whatever product you are using.
By leaving that seal intact you have created a situation in which the resistance to exit out the back is less than the front.
Sometimes this rod is too big for your desired tip size so you need to find something thinner which can puncture the seal.
    Yes, it took me some years to realize that THAT is what that weird little wire was for. :) Feb 4, 2022 at 18:33
    Yeah, but then you gotta wipe it, and it's never long enough anyway. Handy in a pinch though.
    – Mazura
    Feb 5, 2022 at 3:11
