Is there a minimum distance between two exhaust vents going out an exterior wall?
I'm in the state of New Jersey and I was unable to find anything related to minimum distance between two exhaust vents going out through an exterior wall.
Edit: The exhausts are for a Tankless Water Heater (Navien NPE Series) and I believe an HVAC/Furnace. These two appliances are on the 1st floor of a 2 floor house. The room above it is a bathroom
I believe both appliances are receiving their air from outdoor intakes. I've attached a page of the manual for the Water Heater on "Venting Types".
Page of Water heater manual Page of Water heater manual continued
    Sorry, its for a tankless waterheater and an HVAC/Furnace. Im asking on behalf of my brother in law Feb 2, 2022 at 23:39
  • Not my area, but these are both exhausts for combustion gasses with no chance of leaking into the building? I'd wonder if both can be combined in a manifold and exit the structure together through the same exhaust, because fewer holes in your house, the better.
    – Criggie
    Feb 3, 2022 at 0:27
  • @Criggie well I am not sure. This room is on the 1st floor of a 2 floor house. The room above is a bathroom. Is sharing an exhaust okay for these two appliances if only one of them may be on at a time? Does that make any difference? Feb 3, 2022 at 0:37
    Might be different for exhaust vents, but a few places want separate chimney flues for different heating/fossil fuel burning devices.
    Feb 3, 2022 at 0:43
    My local, they can be in the same chimney(side by side a few inches), but need to be different heights and not combined. Usually the local fire department would know, they deal with combustion gases and CO in homes. They are also probably the ones who need to sign off(or have a say) if any permits needed.
    Feb 3, 2022 at 1:53
There certainly are separation requirements with respect to combustion exhausts and operable windows, doors, and air intakes. Whether there are separation requirements between combustion exhausts is an interesting question.
It might not be tremendously relevant, though: do these appliances burn indoor air, or do they draw their combustion air through outdoor intakes? In the latter case there will be separation requirements between the intake of one appliance and the exhaust of another.
It is common that the installation manual for a combustion appliance will give specific instruction as to required separation. Those manufacturer instructions are additive to, and may even override, any building code requirements.
Edit: Based on the attached drawings, and supposing that neither the furnace instructions nor any other applicable code is more strict, it appears the "J" specification is the one you're after. I would interpret the "vent terminal" to mean the whole assembly if it's the type that covers both the intake and the exhaust, or the pipe and elbow/tee assembly if it's the type where intake and exhaust are separated. Some of the dimensions in the chart specifically state "center line of the terminal" but most don't, leading me to believe the dimension should be measured to the nearest edge of the terminal (that's also the most conservative interpretation).
Diversitech combination vent terminal
So.. if you're working with a combination terminal as above then I guess the minimum separation between them is 12 inches. (image: northstock.com)
Separate pipe intake and exhaust
If you're working with separated intake and exhaust like these then it appears in theory there's no separation required between the two exhausts -- the only mandatory separation is between the intake of one and the exhaust of the other.
It's worth noting that this particular example has a few flaws. The exhausts are below the intakes, and they all use tight elbows rather than long sweep elbows. At least it gives an idea as to how the pair of intakes and exhausts could be grouped. You can read more about that case at hvac-talk.com.
  • I believe both appliances draw their air from outdoor intakes. I attached the page of the Water Heater manual about Venting Types Feb 3, 2022 at 21:36
