Based on the UPC code on the sticker, I have Raco 528 switch box that's been sitting in my spare electrical parts drawer for... ages...
It appears to have holes in the side through which I could drive nails or screws to hold it to the wall, but it doesn't come with nails or screws. Having only used plastic new-work boxes (that come with nails when you buy 'em) and metal boxes in old work, I'm not really sure how to attach it to the wall. There doesn't seem to be anything specified at the Hubbell web site (linked above) about how to attach it, so I'm sure this is just "common knowledge" for those who do it on a regular basis. I am, however at a minor loss at the moment.
Do I simply grab any pair of nails or screws and attach it to the wall, or are there special screws/nails I should use?
Since these boxes can be disassembled and made into gangs, I thought I could screw/nail one single side to the stud, then assemble the rest of the box to that side. Alternatively I could get longer screws/nails and run them through both sides of the box (this seems easier in the long run).
Is there any code reason not to use a long screw from the left side of the box, thorough the box, and out the other side to mount it to a stud on the right? I can see the possibility that the screw threads could damage the wire insulation...
Since we're at the "pouring rain prior to the next snowpocolypse" stage of weather, I'm not really looking forward to heading out to pick up something special, but will if I need to.
