I had about 20' of pipe coming out of the house that gave out after 6 years. I wanted to know what's the best way to secure it in place to keep it secure from movement. I temporarily put two stakes with a screw zip tie.
    Burial is a good way, and also gets it out of the sunlight that destroys PVC pipe.
    Jan 31 at 3:27
    What sort of movement are you trying to prevent, and is this a temporary fix until springtime (based on the snow in your photo), or are you looking for a permanent fix?
    – Milwrdfan
    Jan 31 at 3:46
  • Burial (below the frost line) will also prevent the sump water from freezing in the pipe which would prevent the sump pump from being able to do its job.
    Jan 31 at 13:36
  • Burial is currently not an option. In the interim, I'm looking for a way to ensure the pipe doesn't move due to wildlife or someone tripping on it.
    – Kermit
    Jan 31 at 15:58
