I wanted to upgrade my room with a loft bed that way I may have more workspace. My room is 60W x 74.5L x 95.3H. The loft bed design is 28W x 70L x64.5H. I am not allowed to mount anything on the walls. I have no experience with wood projects. I have seen 2x4 and 2x6 have been commonly used for affordable projects. How do you know which and how many triangle brackets to use? My greatest concerns are the legs and support beams for stability. Is there a trick behind that?
Units: inches
Materials:
  • multiple threaded hex bolts/washers/nuts (3/8 x 5)still figuring out type of fasteners
  • 4 steel triangle brackets (8x 12)
  • 4 white pine wood [leg01] (2x4x 62.50)
  • 4 white pine wood [leg02] (2x4x 58.5)
  • 2 white pine wood [back support beam](2x4x 70)
  • 2 white pine wood [inner rail] (2x2x 61.75)
  • 2 white pine wood [slats] (2x3x 24)
  • 8 white pine wood [slats] (2x4x 24)
  • 4 white pine wood [teeth] (2x2x 3.5)
  • 12 white pine wood [teeth] (2x2x 4)
  • 2 white pine wood [side rail] (2x6x 70)
  • 2 white pegboard MDF [side support] (48x 24)
9
    Welcome. Your post formatting was a disaster, with most of your text buried in image descriptions. I've attempted to salvage it, but you could do to revise further. You should not be asking about "science", but something clear and specific about your project. As it is I'm not sure what the question might be, so the post is off topic as too broad. Please revise to focus.
    Jan 25, 2022 at 22:22
    1- Keep in mind that a 2x4 is actually 1.5x3.5, so 2 x 2x4 is actually 3x3.5. Which is quite strong, but when it comes to measurements, that will matter. 2 - I'd be leery of relying on just the pegboards for front/back stability - a 2x4 across each short side at the bottom of the pegboards would make a big difference. Jan 25, 2022 at 22:56
    TLTR. In a seismically active area, I’d attach it to the wall.
    – Lee Sam
    Jan 25, 2022 at 23:26
    That looks very narrow for an 'adult' bed.
    – brhans
    Jan 26, 2022 at 0:35
    Rails for the top bunk? 28"w is really narrow (as stated above), you will roll off. And you don't provide expected load; be sure to use nails and screws on the 2x2 to prevent it from pulling away. Also, I would use real wood for cross bracing at an angle on all sides and not bother with the straight pieces on the back or metal braces. Also, don't forget something under the feet of the bed to protect the floor from damage. Jan 26, 2022 at 3:13
At 70cm (28") the bed is too narrow. It's basically the width of my shoulders. To sleep comfortably in a single bed, a 90cm wide mattress (35") is way better.
You need rails to prevent you from rolling over while sleeping and falling off. Besides, if you attempt to reproduce on that thing, you will fall off and die, which kinda defeats the purpose.
If you can't fasten it to the wall studs, then it will probably be unstable and fall over. Since the room is too narrow for it to fall over, it will crash into the wall and destroy it (most likely with some of your fingers stuck between the wall and the bed).
Now, your room is really tiny. In metric, 152.4W 189.23L 242.062H. That's 7 m^2. So the bed will have to take the entire length. I know someone who crammed a complete studio with bathtub and kitchen in that space, so there's hope lol. Yes it's in Paris.
So, this is not really an answer, rather encouragement to rethink the whole thing. For this type of room, if you design the whole thing as integrated (ie, desk+bed) you can have a much better result.
For that you need to post a question with the room floorplan, which must include the door and the window and in what direction they open. Also position of light switches, and anything else that could matter.
It's going to be wobbly, and it might fall over, unless you make a few modifications.
Pegboard MDF will do basically nothing for rigidity. You could maybe scrape by if you put horizontal 2x3s at the top and bottom of the pegboard panels, and a diagonal one across the middle of each. Otherwise, those side panels need to be plywood, at least 3/8" thick.
With this modification, the ridigity of the structure itself looks mostly fine to me, apart from the largest side (which I presume you will have against the wall), which is definitely going to wobble. You do have some brackets, but those and the two horizontal beams are not going to keep it straigtht. Deflection can occur along the length of the boards as well as at the joints (and there's no brackets on those two beams). I would replace them with a piece of plywood that covers the same area as them (or, honestly, a piece of plywood going as far up and down as you can get away with).
The fact that this bed is so narrow means it's going to be harder to keep it stable; if it were wider it'd be harder to put leverage on the structure, but the way it is, even a little bit of lateral motion will change the center of gravity by a lot. If you absolutely can't attach it to a wall...
You mention that the room is only five feet wide (my goodness). In this case, you might be able to use a very simple solution that I've done in small space before -- brace it against the walls. You could put five-foot-long boards at the head and the foot of the bed, that spanned the whole width of the room, and put rubber wedges on either end of both to stabilize them against the wall. Heck, you could do this going the other direction too (70" to 74.5" is only a 2.25" gap on each end).
That said, I don't know how comfortable you are going to be on such a bed, even if it's stable as a rock. I had a phase where I experimented with various compact living arrangements, and I found that anything less than three feet was extremely uncomfortable to sleep on (you have to almost completely raise your body off the mattress to turn while sleeping, for example).
    Pegboard is hardboard, not MDF. The 1/4" variety would provide plenty of diagonal bracing if fastened properly.
    Jan 26, 2022 at 14:24
  • And even if the pegboard was MDF, it would still be fine for diagonal bracing.
    Jan 26, 2022 at 16:13
  • Well, OP said "pegboard MDF", so I assumed that this was some specific product being referred to, although it's correct that pegboard is generally made using hardboard. It's also true that it provides some amount of diagonal bracing, but I stand by the recommendation to reinforce it (as otherwise it would simply flex along the unreinforced axis). Jan 27, 2022 at 23:00
