I have this PVC piping:
It comes out the basement wall, up the exterior wall, and then back through the bathroom wall.
One pipe is carrying hot water, and it's leaking so I want to change for more suitable piping, which appears to be PEX (PPR is available, but the jointing tool looks to be very expensive).
PVC is rigid and uses cheap plastic elbows. PEX is flexible, and while it seems like I can reasonably bend it to achieve the move to the left of a few inches, I'm not sure if the right angles through the wall are best done using elbows such as this one:
or I can just bend it.
Obviously you cannot bend hose at a right angle, so it would need a bend radius each time it goes through the wall. I'm not sure exactly the pressure of the hot water - it's coming in at 1.5 bar, but I assume the (instant, gas, 5 l/m rated) heater is causing a big loss of pressure.
Is there advice about what's the best solution? (The fittings are brass and much more expensive than the PVC ones, but I suppose buying three of them is not the end of the world, it just seems wasteful.)
